Group: DynoMotion Message: 11249 From: Hardy Family Date: 3/20/2015
Subject: Direct FPGA set/clear bit
I implemented I2C via bit-bang on my new breakout board, and am trying to optimize its speed.
Using the code that you provided on a previous thread (related to SPI, but should apply to I2C) I could not get the direct FPGA writes working.  The commented-out code does not work, but the normal function calls do work.  scl_bit is 30.
    for (;;) {
        //FPGA(BIT_SET+(scl_bit>>3)) = 1<<(scl_bit&7);
        //FPGA(BIT_CLR+(scl_bit>>3)) = 1<<(scl_bit&7);
        SetBit(scl_bit);
        ClearBit(scl_bit);
Running this gives about 750ns between edges (1.5us period).  With the FPGA direct writes, the output stays high.
The reason I would like to use direct writes is that I have multiple bits to manipulate since I have 4 I2C buses (and the bit numbers are contiguous).  Since I/O is so slow, it is important to get the most possible work done with each I/O, so setting multiple bits at once is useful.
Using a Kflop with Kmotion version 432.
SJH
Group: DynoMotion Message: 11250 From: TK Date: 3/20/2015
Subject: Re: Direct FPGA set/clear bit
Hi SJH,
BIT_CLR performs an "and" operation. Try adding a "not":
FPGA(BIT_CLR+(scl_bit>>3)) = ~(1<<(scl_bit&7));
On Mar 20, 2015, at 12:27 PM, Hardy Family hardy.woodland.cypress@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
    for (;;) {
        SetBit(scl_bit);
        ClearBit(scl_bit);
SJH
Group: DynoMotion Message: 11251 From: Hardy Family Date: 3/21/2015
That bitwise inversion was not in the SPI code you posted in the thread about getting SPI working.  Is this a difference in the FPGA since that time?
So tell me if I've got this right: writing to the BIT_CLR location turns off just those bits which have a zero in the written value?  And BIT_SET turns on only those with a '1'?
Also, since I am doing I2C which requires open collector drive, for the SDA lines I need to manipulate the I/O direction.  There is a BIT_DIR location for that, but I presume that I need to keep a shadow register for that to avoid affecting unrelated I/Os.
Is there an existing I/O direction shadow that I can use?
And one last question: is there a 16-bit version of those BIT_DIR locations?  The reason I ask is that I have had to use I/Os 34,35,44,45 for the 4 SDAs, so if there was a 16-bit write then I could hit all of those bits (selected from 32..47) in one fell swoop.  That would be awesome.  I see there's a #define FPGAW(X) macro in KMotionDef.h which looks like it would do the job, but I just want to make sure.
SJH
On Fri, Mar 20, 2015 at 6:36 PM, TK tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi SJH,
    for (;;) {
        SetBit(scl_bit);
        ClearBit(scl_bit);
SJH
Group: DynoMotion Message: 11252 From: Tom Kerekes Date: 3/21/2015
Attachments :
Hi SJH,
No sorry that was a bug in the code example.  Attached is a corrected version (untested)
Correct
Yes.  See code example we use below.   If you know there will be no Thread safe issues you can skip the atomic stuff
void SetBitDirection(int bit, int dir)
    if (bit < N_BITS)
        unsigned int word = bit>>5;
        unsigned int port = bit>>3;
        unsigned int rbit = bit&31;
        if (dir)
            AtomicSet(&BitDirShadow[word], 1<<rbit);
            AtomicClear(&BitDirShadow[word], ~(1<<rbit));
        FPGA(BIT_DIR+port) = (unsigned char)(BitDirShadow[word]>>(8*(port&3)));
No sorry there isn't
